Has anyone ever used liquid electric tape? - Fuelly Forums
Old 06-09-2006, 07:46 PM   #1
Matt Timion's Avatar
I can't find my heat shrinks so I used some of that liquid electric tape for my wiring needs.
I'm unsure if it will hold up, or protect to the right degree. Has anyone used it? Any thoughts?
Old 06-09-2006, 08:14 PM   #2
GasSavers_Ryland's Avatar
I've used liquid electrical tape, and have been less then impressed with it because of how stiff it is, and poor it bonds, I prefer the heat shrink that has the soft glue in it to better seal the connection, for wiring harness repair I've been useing a silicon electrical tape that I found in the electrical section, it only sticks to it's self, and is extreamly flexable, simaler to that weird tape that comes on wiring harnesses, only softer.
Old 06-09-2006, 09:33 PM   #3
I have a bunch of connections done with liquid tape. All of the connections are also soldered, and I've probably put 3 coats of liquid tape on top. I may end up putting some real electrical tape on top of that tomorrow.
If I could do it over I'd just use heat shrinks but I've already put enough time into the project. I guess I'll just trouble shoot the wires as they become problems.
Old 06-10-2006, 02:45 AM   #4
sealing
I use red and black and find that it dries out and tends to crack off. Use some good old silicon sealer glue $2-$3 for a cauk gun size tube - use clear and that way you can see the joint if corrosion sets in.
Old 06-11-2006, 07:17 AM   #5
if you use silicone, make sure it's not acidic acid based (smells like pickles) or it will eat copper rather quickly, silicone II calk is not acid based, and is safe, as are I'm sure some glues, but the tubes of silicone II calk are going to be the cheapest.
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 07:41 AM
iPhone WebApp? Billie Fuelly Web Support and Community News 11 08-09-2008 12:59 PM
Can someone give me the abridged version... Bunger General Fuel Topics 11 03-22-2006 07:32 AM
