Hard to find datasheets? - Fuelly Forums
Old 08-26-2009, 03:34 PM   #1
More importantly, OEM equipment datasheets.
I'm modifying my stock CD player(well, tape first to prove concept and then am going to modify the cd player). The reason for this is to add extra inputs while staying with the stock look, mostly. Once you start the car you'll notice that there isn't typical Vacuum Florescent Display behind it but a dot matrix one. How many people would notice that I don't know.
The stock head unit has zero aux inputs and I plan on adding about 3 of them. One for the mp3 input, one for the XM, and another for whatever I decide to add later. I've thought of making it HD radio but the cost and learning curve of it all will be insane if I add too much.
- Kyle
Old 08-26-2009, 06:02 PM   #2
Just look up chips until you ID the amp, look up the reference circuit design and I bet it comes close.
Old 08-26-2009, 10:11 PM   #3
GasSavers_JoeBob's Avatar
You might check to see if a Sam's Photofact set is available for your stereo.
Gas cards to help track mileage? Pele2048 General Fuel Topics 3 08-12-2011 04:37 AM
Chevy Volt Mark0 Fuelly Web Support and Community News 2 12-18-2010 05:50 AM
DIY: Make a PVC Catch Can for your PCV System GasSavers_TomO Experiments, Modifications and DIY 7 07-12-2008 03:24 PM
Wheel covers Telco Aerodynamics 6 05-27-2007 06:25 AM
Honda CRX HF Gearing ...and/or engine swap Brian D. General Fuel Topics 36 09-06-2006 06:09 AM
