Gas prices on the move again - Page 2 - Fuelly Forums
Old 03-17-2006, 04:52 PM   #11
Matt Timion's Avatar
Re: increases
Originally Posted by JanGeo
we have web sites here to price the gas
http://www.rhodeislandgasprices.com/index.aspx?s=Y&fuel=A&area=M...
Those websites are available for everyone. SOme creative person purchased _______gasprices.com for every major metropolitan area and every state.
You can also check out www.gasbuddy.com to get your local gas prices.
Old 03-17-2006, 08:40 PM   #12
Compaq888's Avatar
I use
I use losangelesgasprices.com same site as any _______gasprices.com
Of course most the time I can't use the stations that are posted there because they are too far away but I still post prices for other people to see.
Old 03-17-2006, 10:47 PM   #13
I'm up for the test. Think
Think the oil in the mower should be changed every test? lol, we could even test various oils out that way...?
I do think the test would be better if I let the mower cold soak for one day before the start of the next test.
-unknown
Old 03-17-2006, 11:35 PM   #14
Compaq888's Avatar
do it. I personally think
do it. I personally think Shell will get you further.
Old 03-17-2006, 11:48 PM   #15
agreed
ok. And I personally agree with you as my best mileage this winter was Shell. Should I start with Shell? Where to from there?
-unknown
Old 03-18-2006, 03:45 AM   #16
hot cold
Hummm . . . maybe you should start with the engine already hot so to make the test go faster and eliminate any other variables. This way you run it dry on one fuel and refill with the next and start with a hot engine. This will allow you to run more tests more quickly and perhaps repeat the test for more accurate readings as well as in case the engine changes operation from test to test. Will also allow testing with additives as well. You may want to run a funnel for a gas tank instead of the regular tank so you can see the fuel used to the last drop and add it more easily or even a long clear hose to watch the fuel being used.
Old 03-18-2006, 06:50 AM   #17
gas went up here too last
gas went up here too last week. from mid 70's (cents/liter) to 94/L
0.94 * 3.785 L/gal (US) = $3.5579 CAD / gallon(US)
= $3.07219 USD/gallon(US) at yesterday's exchange rate
i think the highest i have seen locally was 98 or 99/L last fall (katrina)
Old 03-18-2006, 06:55 AM   #18
the lawnmower test is a good
the lawnmower test is a good idea. i'd like to see the same brand of gas run through the mower several times in a row, to get an idea of the variability of the test.
Old 03-18-2006, 07:16 AM   #19
Me too. But how many times
Me too. But how many times would statisticly be worthwhile? Three maybe? So far I am going to start with shell. I can use the funnel method to be accurate on the amounts used also.
-unknown
Old 03-18-2006, 10:03 AM   #20
Exciting! Post this up in
Exciting! Post this up in the experiments thread so it's in a proper area.
Also, what kinda lawnmower will you be using?
And what's the funnel method?
change? lilspoon Fuelly Web Support and Community News 1 02-17-2012 12:13 AM
Hydrogen or H2O Systems 1Jal1 General Fuel Topics 4 10-11-2008 02:20 AM
can receipts be entered in any date order? mauirixxx Fuelly Web Support and Community News 9 08-29-2008 03:21 PM
