Extra Compressor Oil - Page 2 - Fuelly Forums
Old 09-17-2010, 03:01 PM   #11
lamp and candle oil
didn't want to start a new thread, but i had a question about lamp and candle oil. i found a (not quite full) half gal container of the stuff in my new house and was wondering if i could use it in my car or mower. thoughts?
Old 09-17-2010, 04:25 PM   #12
Re: lamp and candle oil
Other than burning it in a lamp the only thing I might consider using it for is bar oil in a chain saw. I would not add it to any engine oil or engine fuel supply.
Old 09-20-2010, 08:29 AM   #13
Re: Extra Compressor Oil
Likely too thin for bar oil.
It may just be kerosene or kerosene substitute. Unless it's scented, I would use it for bbq starter fluid if you didn't have a lamp.
Old 09-20-2010, 08:40 AM   #14
No way I'd use a random oil for BBQ starter fluid, wouldn't want it potentially getting in food.
Old 09-20-2010, 11:27 AM   #15
yup, too thin for bar oil. if it is mostly kerosene, wouldn't that be ok to use in a car in small amounts?
Old 09-20-2010, 12:04 PM   #16
I would not use it in an engine. It may contain small amounts of paraffin dissolved in it. This may lead to nasty deposits on valves and fuel injectors, and possibly fouling plugs, O2 sensors, and catalytic converters.
Old 09-21-2010, 04:45 AM   #17
Just use it to start your next bon fire...
ben98gs is offline   Reply With Quote
Old 10-27-2010, 05:57 PM   #18
Ever since the 70's, in the old thunker 100 gal 2 piston compressor, to the modern 10 gal portable shop compressor, I have always used non detergent 30 wt oil. Never had a problem, just change it when it looks funky.
I dont know about using it in a car. I still use 90% multigrade synthetic, with 10% 30 wt oil to protect the bearings during start up.
i need a new car Hockey4mnhs General Fuel Topics 7 07-01-2008 05:11 PM
just downsized from suburban!! GasSavers_soccermom Introduce Yourself - New member Welcome 2 05-18-2008 06:16 AM
Noobie seeking guidance/assistance JohnBeLaze Introduce Yourself - New member Welcome 14 04-17-2008 07:09 PM
Scanguage II out of the U.S. Erdrick General Fuel Topics 10 10-31-2007 09:40 PM
W9 Configuration engine GasSavers_DaX General Discussion (Off-Topic) 9 01-19-2007 02:58 PM
