Expensive - Fuelly Forums
Old 02-18-2010, 10:14 AM   #1
Expensive
Mantainence costs on Toyota vehicles are supposed to be low, because nothing goes wrong or breaks. Right?
I planned and calculated, plotted and studied before I bought 'Clyde the Ride' and got a very good deal, so I thought I was "in like Flint."
Oops. Seems that, every ninety thousand miles there is a mandatory mantainence, and it is costly. One Large. One C-Note, a grand, one thousand bucks. Hurts even us rich guys. All to replace the timing belt. The parts are half the cost.
I won't do it myself because I lack a crankshaft pulley-puller, torque wrench, motivation and inclination and because the time it would take me is what it would cost a professional to do the job correctly. And I don't give a warranty.
Last vehicle I buy that uses timing belts.
Old 02-18-2010, 11:08 AM   #2
Why do any vehicles use timing belts? What is the advantage of a timing belt over a timing chain, besides (I assume) initial cost?
Old 02-18-2010, 11:57 AM   #3
i've often wondered this as well. the only reason(that's not reasonABLE imo) that i can think of, is the noise issue. a timing belt driven motor is said to run quieter.
Old 02-18-2010, 12:13 PM   #4
Banned
hehehehe
Old 02-18-2010, 12:48 PM   #5
GasSavers_BEEF's Avatar
my cavalier has a timing chain and I don't think it is that loud. I have heard that it makes quite a racket right before it snaps (other cavalier owners) which I would think would be an advantage. 195k and still the original chain.
Old 02-18-2010, 12:53 PM   #6
GasSavers_Erik's Avatar
I think it is probably cheaper for manufacturers to use a timing belt- timing belt covers are plastic (cheap to make and fit doesn't have to be perfect), while a timing chain requires a metal (tin or cast) cover that must fit well enough to keep the engine oil from leaking out.
Also timing belts give the dealer a way to make more $ for routine service.
And they ensure that they can sell more cars -who knows haw many old cars we'd still have on the road if ppl would stop neglecting their timing belts til they break and wreck the valves (on interference engines)
Old 02-18-2010, 01:31 PM   #7
Check to see if it is an interference engine (most Toyotas are not) and drive it until the belt breaks if it won't wreck the engine.
Get a decent aftermarket shop to replace the belt, and while you are in there replace the crank and cam seals as well as the tensioner.
regards
Gary
Old 02-18-2010, 01:49 PM   #8
Design details make a difference but as a general rule;
Belts:
No lubrication needed
Quieter
Self dampening so no weird harmonic resonances
Lighter than chains - usually.
BUT:
Need more space (wider)
Don't take temp extremes well
Need a cleaner environment
Still need tensioner
Can take a "set" if held in one position for a long time.
Cheers , Pete.
GasSavers_Pete is offline   Reply With Quote
Old 02-18-2010, 01:55 PM   #9
I thought the expression was "In like Flynn"...named after Errol Flynn who "never let a chance go by" as the old saying runs.
Pete.
Old 02-18-2010, 02:02 PM   #10
Site Team
Just about every engine nowadays is an interference engine AFAIK.
Besides being quieter, timing belts help the knock sensor to be more sensitive (don't get me going on that one again).
In the old days, Buick used to use nylon-covered timing gears. However the nylon would eventually fall apart, causing all kinds of fun (such as plugging up the oil pickup and skipping a tooth, ask me how I know). Replacement units are steel.
-BC
Crackling Exhaust Roar shatto General Discussion (Off-Topic) 4 08-01-2009 10:02 PM
Police Hybrid? Wyldesoul Hybrid Vehicles 4 05-27-2008 02:16 PM
Kenwood KAC-PS401M popimp For Sale 1 07-30-2007 02:53 PM
Hyundai Excel manual gearbox question Spule 4 General Maintenance and Repair 4 07-13-2007 05:04 PM
Another new one to GasSavers from N. TX retrorocket Introduce Yourself - New member Welcome 5 05-29-2007 05:27 PM
