EGR troubles (need an expert) - Fuelly Forums
Old 02-09-2010, 04:43 AM   #1
GasSavers_BEEF's Avatar
my car lately has been throwing an error code (p1404) which means the EGR is stuck open or closed or something. this is an issue that I have been dealing with for a while.
what I have done:
cleaned the EGR valve twice (replacing the gasket both times)
purchased a new EGR valve and replaced the old one
the code came back on me yesterday. there is a website where you can ask questions of ASE certified experts. I have joined that site (it is a pay site) and am having difficulties with the site. you are supposed to be able to ask follow up questions but for some reason I just can't get it to work and their customer service hasn't responded to me.
here is what he said.
Hello!
P1404
Tests/Procedures:
1. Disconnect the battery and touch the cables together for a couple minutes. Reconnect and then check actual percentage and see if the actual egr matches the desired egr position.
2. If not, then use the scanner, and in the functional test area see if the scanner offers a reset for learn EGR value.
3. If the scan tool does not do this, then would have the Powertrain Control Module (PCM) flashed with the latest software.
Potential Causes:
Powertrain Control Module (PCM) Reflash
if anyone knows what I need to have to monitor the positon of the EGR valve or what it might cost to reflash my PCM, please let me know.
I am pretty sure the scangauge won't tell me what I need to know.
I am thinking of just disconnecting the battery and shorting the leads to see if a reset will fix it.
any information is greatly appreciated.
Old 02-09-2010, 09:18 AM   #2
try the reset after all its free.
im assuming you have the 2.2L?
thats what my truck is and i completely removed the egr and just blocked it off with a plate. still throws the ses light but meh i know whats causing it
Old 02-09-2010, 09:23 AM   #3
I plan on doing the reset tonight.
my big problem is that I need the CEL off to pass inspection and I am pretty sure the system has to be in the "READY" state to pass as well. inspection is due in march.
if I can get it past this inspection period, I don't really think I care much about it.
and it is the 2.2
Old 02-09-2010, 03:23 PM   #4
ohhh sucks about inspections...
hmm might be cheaper to find a PCM out of the same year and model of car at a junkyard for cheaper...
Old 02-10-2010, 07:49 AM   #5
Site Team
So it sounds like the EGR is not working because the PCM is not giving it a good signal? Unless there is a blown fuse or something, it sounds like the only other fix is to replace the PCM. That's really annoying since 99.99999% of the PCM is working fine, just the output control to the EGR is broken.
It might not hurt to do a continuity check in the wires too. Just in case a wire got pinched or something, and the signal is being sent by the PCM but the valve can't "hear" it.
I'm assuming you don't have a scan tool.
-Bob C.
Old 02-10-2010, 08:10 AM   #6
I checked on a scantool and they run in the neighborhood of $6k so I don't plan to get one and I am not a mechanic by trade so I don't have access to one.
I did find a guy on ebay that sells PCMs and he flashes them for you before he sends them. he uses your vin to get the specifics of your vehicle (ie. motor size, transmission, other stuff) he charges just under $100 shipped.
that is a consideration but for now, I have reset the pcm (just unhooked the battery for a few hrs) and I am going to run it for a week or so. if the light does come back on, I will look into tracing wires before purchasing anything.
for now, I am waiting and watching. if I can get it to say "READY" even for just a little while, I can get an inspection and not worry about it. if the light comes back on after that, it isn't that big of a deal.
Old 02-13-2010, 09:25 AM   #7
UPDATE (and a sigh of relief)
after 120ish miles, my car finally go to the "READY" state and a raced out and got inspected. hopefully that was my problem.
even if the problem comes back, now I have a year to deal with it.
thanks to all.
Cars/Trucks - Overachievers. GeneK General Fuel Topics 7 09-06-2009 09:36 AM
Hi !! Any Suzuki Drivers Here ??? fitsandy Introduce Yourself - New member Welcome 1 09-09-2008 04:44 PM
Stealth / Performance Exhaust System Hybrid JohnNeiferd General Fuel Topics 9 07-27-2008 03:40 PM
Fess up, which one of you owns this thing? GasSavers_ALS General Fuel Topics 5 05-07-2008 05:24 PM
Happy 1st Anniversary Geo! Peakster General Discussion (Off-Topic) 11 08-20-2007 08:07 AM
