Computer heater - Page 4 - Fuelly Forums
Old 10-09-2007, 07:50 PM   #31
trebuchet03's Avatar
Originally Posted by skewbe View Post
It still needs a temperature differential to work.
That's what I mean by "Use a Peltier effect plate backwards" --- give a thermocouple a current, it will make a temperature difference :P Give it a temp. difference, it will make a current
So is there anything special about a solar cell in this regard? What if you could make one that responded to infrared radiation, would it care if it was bathed in heat?
PV panels in space aren't bathed in heat
In any case, you can do some interesting things by using LEDs in reverse Give a red LED some red light - and you should get a voltage over the leads This has been used for simple multi touch experiments among other things
11/12
Old 10-09-2007, 08:02 PM   #32
3rd Law
Does this have anything to do with the 2nd Law of Thermodyamics...
I took a lot of bio-science classes instead, darnit
EDIT: Crap, I can't edit the Title -- OK, I thought it was the third until I looked it up...my bad
Old 10-09-2007, 08:56 PM   #33
Pretty much
The second law says - you create entropy until you reach equilibrium and max entropy happens to be at the point of equilibrium.... Or something along the lines of - system order can not increase in a closed system (given no external energy source, you slowly diverge to disorder) - you know - no free lunch
So put a cup of hot coffee next to a glass of ice water... And you're an entropy terrorist! Contributing to the ultimate destruction of the universe
Although, if you destroy the universe (and thus space-time) - did the universe ever exist given the absence of time o.0 I mean, "infinite" and "forever" are until time ends - which is theoretically finite
11/12
Hovercraft 88HF General Fuel Topics 2 06-21-2007 10:41 PM
partial boat-tail MetroMPG Aerodynamics 34 09-10-2006 05:43 PM
94 Geo 4dr Hatchback JanGeo For Sale 3 09-10-2006 02:05 PM
Metro 3-cyl General Info 95metro General Maintenance and Repair 34 07-13-2006 09:39 AM
"Magic Pill" for gas mileage? diamondlarry General Fuel Topics 11 03-24-2006 05:05 PM
