Checklist for no spark? - Fuelly Forums
Old 07-30-2006, 10:54 AM   #1
Inquiring for a friend, got any good links?
Old 07-31-2006, 08:25 AM   #2
What kind of car?
Old 07-31-2006, 08:26 AM   #3
92 VeeDub Jetta, cranks and cranks but ain't sparking.
Old 07-31-2006, 08:33 AM   #4
When he's cranking it does he get any spark from the coil, if you unplug the coil from the distributor cap and hold it close to a ground?
Old 07-31-2006, 08:34 AM   #5
SVOboy: Let me chew on this, whilst I go to the Chiropractor. I'll try to give you some idea's of thing's to consider/check.
Old 07-31-2006, 08:38 AM   #6
I'll ask him. He did replace the coil but it didn't change the situation. Right now I think he's picking up another dizzy (it was like 10 bucks shipped on ebay).
Old 07-31-2006, 09:44 AM   #7
I'm getting an intial spark from the coil (one arch)
by placing the a screw driver in the coil wire (the
one that goes to the distibutor) and holding it
against the engine block.
This happens when I turn the car on.
Is what he said.
Old 07-31-2006, 11:05 AM   #8
SVOboy: I'm not sure what might be causing the inital spark from the coil. I would think it would suggest the coil is Ok. I have encountered a problem on my daughter's 87 Honda, where the ignition pickup electronic's, in the distributor, got extremely flaky and finally died. I ended up getting a used module at the pick a part and then pulling the dissy, replacing the pickup, readjusting the pickup gap and putting it back in. I presume if he got a dizzy on eBay, it is probably used, but it should be fine to just swap in and hopefully that will fix it. Keep us posted.
Oregon-Washington: Winter gas ending, summer gas formula starting? 740dan General Fuel Topics 5 02-26-2013 09:17 PM
US / metric switching problems gory Fuelly Web Support and Community News 4 01-24-2011 02:04 AM
miles between fuelup limit? drnknmnky13 Fuelly Web Support and Community News 6 09-14-2010 03:08 AM
Tracking Monthly Fuel Expense Taser Fuelly Web Support and Community News 2 11-09-2009 11:40 PM
TDI EPA figures off? bates General Fuel Topics 14 09-15-2009 08:04 AM
