Car wrecked. - Page 8 - Fuelly Forums
Old 06-09-2006, 03:12 PM   #71
Originally Posted by Compaq888
When I go to refuel I just guess a number and it comes out to it really close.
Compaq, Compaq, Compaq... You're not even in the ballpark this time:
In the secret sauce thread you said your car gets 39-40 MPG on the freeway @ 55 PSI.
http://www.gassavers.org/showthread.php?t=1046
And several posts back in this thread you said that you can tell by looking at your fuel gauge vs. odometer that you're 2-3 MPG lower than normal.
But if your gauge is at 22 miles where you say it would "usually" be at 35-40 miles, then your mileage is actually off by 37% to 45%. ( (35-22)/35 to (40-22)/40 ) That's waaaaaay more than 2-3 MPG!
If you're normally getting 39 MPG freeway by this point on the gauge, then you just used a gallon to go 22 miles. That's 17 MPG less, not 2-3 (EDIT: fixed my percent MPG mistake posted a second ago.)
I don't doubt that someone can *estimate* fuel used if you *really* know your gauge (even more closely when it's a small capacity tank).
But seriously Compaq - you've got to stop picking numbers out of your a** and attributing them to things unless you can support what you're saying.
Either that or shake the magic 8 ball and get some better numbers!
Old 06-09-2006, 03:53 PM   #72
Compaq888's Avatar
I use the fuel gauge and the odometer obviously. You can't just go by one.
Old 06-09-2006, 03:54 PM   #73
I give up.
Old 06-09-2006, 04:11 PM   #74
krousdb's Avatar
Nevermind.
Old 06-09-2006, 06:25 PM   #75
Compaq888's Avatar
The car is weird what can I say???? You guys know my car is the weirdest one on this site.
Old 06-11-2006, 08:16 PM   #76
|V3|2D
thisisntjared's Avatar
The car is dumb what can I say???? You guys know my car is the dumbest one on this site.
Old 06-11-2006, 10:07 PM   #77
Compaq888's Avatar
very uncool to put that stuff in the sig.
You guys look down on me because I try to calculate everything. I always look at something and calculate what will happen and all the possible outcomes.
Old 06-13-2006, 09:50 PM   #78
|V3|2D
man you are confused. dude its because you do it wrong.
Old 06-14-2006, 11:04 PM   #79
Compaq888's Avatar
Even if I'm wrong it doesn't change my mpg. I'm only guessing.
Old 06-14-2006, 11:23 PM   #80
philmcneal's Avatar
well maybe to all people have all werid sorts of way to record their own mpg. And some people believe that they know their own car and knows what they are suppose to get when the needle is pointing at a certain angle. All Compaq wants to say is when the needle looks like its calibrated while he's maintaining a constant speed is that he gets 75 miles when ther needle is pointing at 3/4's full. I could say the same for my car but mine reads 130 miles since I notice for my gas gauge two it has certain stages, and its pretty linear once you notice it. And for us gas freaks we sure do, although its not a number to use for science but its still a number that will evenually predict your mpg unless you decide to make it for better or for worse...
its just everyone else prefers the pump calculated ways since its as accuate as how much you pumped in the tank. So at a fill I would take the number that i RESET LAST FILL and then write it on the reciept that I am going to get right this moment. That receipt should contain the number of liters/gallons I pumped in, and by writing the number of km/miles i got from the odometer I can go home, do the math and then input that number on three different databases for safe keeping =)
then screw the recept.
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 03:01 PM
VW Jetta fast riser coolbreeze General Fuel Topics 5 07-22-2009 12:25 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
Modifying exhaust to increase mileage? Matt Timion General Fuel Topics 15 01-07-2006 08:44 PM
