Car wrecked. - Page 5 - Fuelly Forums
Old 06-02-2006, 11:34 PM   #41
Compaq888's Avatar
Originally Posted by thisisntjared
see now if you had a clutch you wouldnt have trouble at all. where do you launch? usually nitrous boosts the super low rpms torque through the roof and doesnt aid much in the higher rpms, but that varies from car to car. i know thats the general rule of thumb with our 4bangers. you could try spraying later in 1st gear if you were having that much trouble off the line. whats the 60'? and whats the best n/a run?
yeah torque is true about nitrous especially with my engine. I tried spraying later and all it did was slow me down. The best run under a 75 shot I got spraying 3.5k was a 16 flat. I got about 200 ft of torque at 2500rpm with a 75 shot. If I had a header it would of been like 230 ft lbs. One guy had a i/h/e 75 shot, auto, safc2, same engine he made 260+ ft lbs.
On the 15.7 run my 60' was a 2.5 ROFL
I quit nitrous because most guys that used it blew their engine. The KA24DE has a weak piston design. Once the pistons and all the other components are upgraded the engine is spectacular. There is even a KA24DE running around that's making 718 whp.
Best NA run is 16.9 I would of broken into the 16.8's but you can see what happened at the track. The engine has potential and so does the tranny. really long gears are good for boost. Especially a lot of boost.
Old 06-05-2006, 09:31 AM   #42
Compaq888's Avatar
I dropped off the car today. I'll be picking it up Friday.
Old 06-05-2006, 09:51 AM   #43
Compaq888's Avatar
son of a *****, the fender that I got from Ebay was damaged. I didn't open it completly because I gave it to the body shop.
Old 06-05-2006, 09:58 AM   #44
Compaq888's Avatar
There goes another $50 to take out 4 dents out of a NEW fender. Unbe****inglievable
Old 06-05-2006, 09:40 PM   #45
|V3|2D
thisisntjared's Avatar
... you need to learn more. longer gears are only better if your having trouble with traction.
Old 06-05-2006, 10:05 PM   #46
Compaq888's Avatar
I know that. And it's really bad if you have short gears on a turbo car because it won't hook up. That's why a lot of people complain about traction in the 1st 2 gears because they are the shortest.
Old 06-05-2006, 11:25 PM   #47
|V3|2D
so traction is good for boost, not long gears. once a gear wont break loose your going to want all of the others to be relatively close.
Old 06-05-2006, 11:50 PM   #48
Compaq888's Avatar
Traction is good period. It doesn't matter what you have but it's good. Unless traction is too good and you start breaking parts.
Old 06-06-2006, 01:52 PM   #49
Jared was saying that gearing and traction are different things, and that gearing isn't the best way to fix traction.
Old 06-06-2006, 03:20 PM   #50
Compaq888's Avatar
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 03:01 PM
VW Jetta fast riser coolbreeze General Fuel Topics 5 07-22-2009 12:25 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
Modifying exhaust to increase mileage? Matt Timion General Fuel Topics 15 01-07-2006 08:44 PM
