Can't find a VX, D15Z1 swap into CRX shell? - Fuelly Forums
Old 06-30-2008, 03:35 AM   #20
Originally Posted by bobski View Post
The VSS is only an issue if you want to change over to a newer gauge cluster - '94-01 Integra and '96-00 Civic clusters are popular. The trouble is that those clusters don't use a cable-driven speedometer - it's all electric. As such, you need to take the old speedometer cable and drive gear out of the transmission and replace it with a transmission-mounted VSS. The new VSS needs power, ground and it's signal wire connected to the old VSS signal wire. Simply tapping into the existing wire conveniently sends the signal to both the ECU and gauge cluster.
With the different gear ratios, if I bolt in a z1 with a hf tranny, the ecu will get the signal to operate the vtec? If so is that with all EF's or just the hf civic/crx
seeodywhy is offline   Reply With Quote
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Frequency Counter as FE Meter? FritzR General Maintenance and Repair 15 11-29-2007 06:47 PM
WTB: Civic VX Wiring dj1000 Wanted to Buy 0 08-22-2007 05:26 AM
Hey people: enter your location in your profile please MetroMPG Fuelly Web Support and Community News 7 02-18-2007 07:58 AM
