Best thing to do for about 100 bucks - Fuelly Forums
Old 08-19-2007, 02:13 AM   #1
fuel economy forum
vegan recipes
green home improvement
honda gas mileage
Old 08-19-2007, 03:45 AM   #2
Rig up some kind of smart meter. ScanGauge for the house.
Old 08-19-2007, 08:58 AM   #3
omgwtfbyobbq's Avatar
Insulation.
Old 08-19-2007, 10:05 AM   #4
88HF's Avatar
What are temperatures like? How big is the house? Are there outside lights? Spotlights?
my favorite thread
Old 08-19-2007, 02:37 PM   #5
fuel economy forum
vegan recipes
honda gas mileage
Old 08-19-2007, 05:42 PM   #6
zpiloto's Avatar
Just a few idea; Weather stripping, Hot Water Heater (HWH) Blanket, check the temp on the HWH, See if there is energy saving modes on the washer and dryer and show her how to use them, programable thermostat, and maybe the turbines or vents (don't know what there called) in the roof to let the heat out in the summer if they don't have um.
Old 08-19-2007, 07:52 PM   #7
fuel economy forum
vegan recipes
honda gas mileage
Old 08-23-2007, 06:30 AM   #8
Originally Posted by SVOboy View Post
How much does a HWH blanket raise the efficiency?
For an electric?
Touch the top surfaces of the tank (not near the piping or relief valve) or shoot them with an IR gun, then compare to other surfaces around you. If it's a few degrees warmer and it's an electric tank, a blanket or a new heater would help although I'm not sure how much. The temp differential of the tank is easier to assess in the winter time when the room is cooler.
Most newer tanks are very good designs.
A simpler response is just to feel the warmth of the tank. If it feels very warm, then it is leaking BTUs.
For NG tanks it's a bit more difficult since they have that big heat wick in the center and the blanket should not get to close to the flue.
Not knowing your climate and thinking like a Canuck...
If it's going to be winter when you get back, with a $100 budget I'd do the following (obtain an IR temp gun - maybe $50 or borrowable) and scan the house from the *outside* on the first really cold night. Consider expanding foam where you find big heat leaks or use other forms of insulation depending on what you are dealing with. Use this gun to help with determining where to put weatherstripping as well. It's all about slowing the heatloss from the house.
A programmable t-stat can often be had cheap (mine was $30 plus I got $15 rebate from the gas company). A few caveats. The savings will be when it flattens out to the lower temp, so don't go too wild or your just putting too much heat up the flue (if the heating system burns oil or gas) on recovery. If you have water heated rads and piping that is exposed, be careful that it doesn't have time to freeze when the temps get set back.
If there isn't a "solar powered clothes dryer" installed, set up a clothesline outside. ;-)
Old 08-23-2007, 12:59 PM   #9
trebuchet03's Avatar
Weather stripping and window film to block out some heat radiation so you can keep your curtain/blinds (whatever) open and not use those CFL's Depending on how many windows you have (and their direction) that will probably put you around $50-$75. Spend the rest on a programmable T-stat (I bought mine for $20 used off eBay, works flawlessly).
11/12
Old 08-23-2007, 08:21 PM   #10
GasSavers_Ryland's Avatar
put a timer on the hot water heater, the water will stay hot for 2+ hours, and warm for 4+ hours, so if your mom is not the kind of person to take long showers at mid night, and she has a day job have the water heater come on about an hour befor she normaly wakes, and turn off about the time she goes to work, then turn on again shortly befor she gets off from work, and turn off a few hours befor bed time, this can cut the energy used by the water heater in half.
with the rest of the money get pipe insulation for the hot water pipes, and a bag of spray can foam to fill all the gaps around the sill plate of the house, around doors, windows, and pipes, if you notice a window is drafty pop off the trim with a flat pry bar and fill the gaps with "door and window" expanding foam, as it is softer and will not bow doors and windows, but seals them nicely.
C-Max Energi TeslaWannabe General Fuel Topics 8 04-20-2013 08:18 AM
More Metric Options pb Fuelly Web Support and Community News 2 08-22-2008 09:53 PM
newbie, would like any suggestions LUMINA93 Introduce Yourself - New member Welcome 3 06-02-2007 03:58 PM
Have you ever participated in a 'Cruise Night' in your city? Peakster General Discussion (Off-Topic) 20 03-27-2007 03:23 PM
Turbolators onegammyleg General Fuel Topics 5 09-06-2006 06:39 AM
