Second odometer for WVO tank? - Fuelly Forums
Go Back   Fuelly Forums > Alternative Fuels > Vegetable Oil and BioDiesel
Old 03-16-2008, 08:02 AM   #1
Jetta90GL's Avatar
I have been looking for a simple way to add a second odometer on my 90 VW Jetta. The idea is to have it start counting miles anytime the WVO selector switch is turned on. One problem is the original VW speedometer is mechanical, so I thought maybe something like a sensor on an axle or wheel? Any ideas?
Jetta90GL is offline   Reply With Quote
Old 03-16-2008, 12:16 PM   #2
Jetta90GL's Avatar
I did some searching and found this:
http://www.spatechnique.com/product_...eedometers.asp
It looks like it uses a simple magnetic pick up, hopefully off of the wheel. I am going to hook its power to my WVO solenoid power so that it only tracks WVO burning miles.
Old 03-24-2008, 12:17 PM   #3
BumblingB's Avatar
Good for you if you have a 90 A2 Jetta and the OEM odometer works in the first place. Sounds like a neat idea. Chime back in and mention how it works as I'm curious. I consider my WVO an additive to the diesel, even though it seems to use much more WVO than diesel.
BumblingB is offline   Reply With Quote
Odo in miles - all other metric 30mbie Fuelly Web Support and Community News 2 05-10-2012 02:44 PM
6Cyl running on 4 TeamExploder General Fuel Topics 6 11-09-2007 06:00 PM
Innovate LC-1 WB O2 sensor Installed CoyoteX General Fuel Topics 12 04-15-2007 04:26 PM
Just fired up the swamp cooler Matt Timion General Discussion (Off-Topic) 13 08-04-2006 05:43 AM
Unburned Fuel rh77 General Maintenance and Repair 11 11-30-2005 08:01 PM
