Tyre pressure is rounding - Fuelly Forums
Old 09-06-2019, 03:32 AM   #1
Country: Portugal
Hello,
I am finding that the tyre pressure value is rounding. For example, if I enter 2.5 and Save Changes, I see '3'.
Also, there is no way to enter multiple pressures. Some motorbikes and autos recommend different pressures for front and rear.
Exptected: When entering the tyre pressure, it should keep the value I enter.
As well, ideally, there would be a way to record multiple pressures. This could be stored in one field. For example, 2.5/3.0 would mean 2.5 front, 3.0 rear.
Work-around: I am entering tyre pressure in the notes field.
Thank you!
razendsnel is offline   Reply With Quote
Old 09-06-2019, 07:19 AM   #2
My guess is that the field is set up with the expectation that the units used are psi, and will only display whole numbers. The entered value is likely still there. The site does the same for fuel prices; only shows two decimal places instead of the entered three.
