Time only on re-edit? - Fuelly Forums
Old 03-16-2011, 05:33 AM   #1
When you Add a fuel-up, no time entry exists. If you go back and edit the data, there is a Time entry. Only I don't see it anywhere else? Is there a way to use this data somehow? Or add a profile option for it/against it?
iceweazel is offline   Reply With Quote
Old 03-16-2011, 05:37 AM   #2
pb
We added it a while back so that if you have more than fuel-up in a day you can set the time to show which fuel-up came first. It's a fairly rare case so we only show the option on edit so you only have to worry about time if you run into the multi-fuel-up problem.
We show the time if you do a fuel-up export, but not on the site. We only use it on the site for sorting, so the earlier fuel-up will appear before the later fuel-up on the same day.
Old 03-16-2011, 05:39 AM   #3
Guess I haven't done an export since it was added. Thanks for the info! That's exactly what I was wondering as I have a long trip coming up, thinking 2 or 3 in a day.
Old 03-16-2011, 05:46 AM   #4
pb
Just double-checked and we were not showing the time on export like I thought we were. So I added that.
