Working As Designed: system not calculating mpg if last fuel up was partial. - Fuelly Forums
Old 09-26-2014, 04:58 AM   #1
Mpg should be calculated for the two combined miles and fuel consumption for both fuellings. Why doesn't it show the average mpg when it is easily calculated
periodictable2 is offline   Reply With Quote
Old 09-26-2014, 05:08 AM   #2
RobertV's Avatar
Fuelly was set up on this belief:
http://www.fuelly.com/faq/3/fill-the-tank
However, we have received quite a bit of feedback requesting the calculations be changed. We're considering it and it may roll out in a future update. No ETA at this time to report though.
Old 09-26-2014, 03:33 PM   #3
That's ridiculous if I may say so! I fueled up locally (partial tank) before a long highway trip so I would not have to pay Thruway prices. Now Fuelly is useless for me... I also fueled up in Michigan before entering Canada as there are extra charges there, so it happened again. You should re-examine this issue.
kavalley is offline   Reply With Quote
Old 09-26-2014, 06:41 PM   #4
RobertV's Avatar
Did you fill the tank up? From what I've heard, usually when gas prices are less expensive than in the area you're going, one tends to fill-up to avoid running low when in the expensive areas.
Only reason I ask, is because that would not be considered a Partial fill.
