Originally Posted by ViperGuy
When I add a fuel up the stats are completely different from what i entered.
If I go to edit the fuel up it shows the correct info.
I even added 2 new cars with the same info to see if it would work but it does the same thing.
http://www.fuelly.com/car/subaru/imp...iperGuy/295896
My other 2 work fine.
Thanks
Your first fuelup has an odometer of 211.2
Your second fuelup has an odometer of 95
Your third fuelup has an odometer of 272.5
It seems that your second fuelup is really your first. Your odometers need to be in the correct order and they aren't currently. If 95 is really your first fuelup, edit the second fuelup and change the date/time to be before you 211.2 odometer fuelup.
