Problems with odometer MPG (Incorrect calculations) - Fuelly Forums
Old 11-25-2012, 05:41 PM   #1
Hi
I've used Fuelly before for another car.
I've recently started to use it for my new car using the odometer setting.
So, I've filled up twice and to my calculations I should be at 45MPG or thereabouts. Yet Fuelly is saying 90+MPG.
You can see my profile here
http://www.fuelly.com/driver/skymera/micra
20th Nov I make my first fill of 14.82Litres @ 134.9/L with an odometer reading of 86,527. No MPG reading as expected.
23rd Nov I make another fill of just 7.42Litres @ 133.9/L with an odometer reading 86,676.
Which is 149miles for the 14.82L I filled up on the 20th.
So why is Fuelly calculating it to be 90+MPG?
It's as if Fuelly is calculating 149miles from 7.42Litres which is wrong.
Thanks, any help appreciated.
skymera is offline   Reply With Quote
Old 11-25-2012, 10:05 PM   #2
pb
Did you get this one figured out? I'm looking at your vehicle now and I see 45.7 UK MPG. It sounds like that's what you were expecting to get.
Old 11-26-2012, 02:45 AM   #3
He now has both refuellings entered as 14.82 litres.
From the description it sounds like the second refualling should have been entered as a partial (very close to £ 10 worth of fuel, my guess is that it was not filled up all the way).
Why is that wrong? It's only wrong if it's a partial-fill.
86,676 - 86,527 = 149 miles
Old 11-26-2012, 03:01 AM   #4
I managed to fiddle about with the fill ups and got the number I was looking for.
MMUK: I didn't get 149miles for 7.42litres.
I filled 14.82L, drove 149miles and then filled up 7.42L.
BUT looks as if I got my numbers slightly muddled up which doubled my MPG. Seems to be sorted now.
Cheers for replies anyway fellas.
Old 11-26-2012, 10:51 PM   #5
Did you fill it up all the way to the top, or did you do a partial fill (e.g., putting in £10 worth)?
But that is what fuelly will use to calculate your mpg. The amount you filled up (7.42L), and the distance you drive prior to filling up (149 miles).
