Fixed: Problem with "Chart all Fuel-ups graph display - Fuelly Forums
Old 06-11-2014, 02:56 PM   #1
Since the upgrade I noticed a problem with "Chart all fuel-ups" link.
No MPG is displayed when you hover your mouse over a fill up unless you go to the very first fill up. Only then it will display your most recent fill up, when you select your first fill up.
This problem started today after the upgrade announcement.
I also see the amount of gallons entered does not change when you go back to edit it. It will display correctly on my dashboard but not when you go to re-edit the fill up.
dobrien14328 is offline   Reply With Quote
Old 06-11-2014, 10:55 PM   #2
in the yearly charts it counts the notes as fill-ups now.
PlasticFantastic is offline   Reply With Quote
Old 06-12-2014, 05:01 AM   #3
Fuelchart not supported?
It looks like this link doesn't work after the update:
http://www.fuelly.com/driver/cobrapa...phev/fuelchart
Is fuelchart still supported?
Thanks!
cobrapa is offline   Reply With Quote
Old 06-12-2014, 07:39 AM   #4
Out of Fuel
Take a look at the chart now. The data points should display.
fbingha is offline   Reply With Quote
Old 06-13-2014, 07:45 AM   #5
The old fuelchart links are still not working. Is the format changing and is that the new format for links? There is now a random number in that link (link at a different level.) Should that be used instead?
Thanks in advance
Old 06-13-2014, 08:45 AM   #6
Out of Fuel
Yes, you should use the new link.
