NO MPG after EDIT - Fuelly Forums
Old 07-25-2014, 12:41 AM   #1
NO MPG after EDIT
When I edit my fill upafter a mistake the MPG's go away.
papajack is offline   Reply With Quote
Old 07-25-2014, 04:29 AM   #2
MPG didn't work today. Wutz up wid dat!!!???
mark23487 is offline   Reply With Quote
Old 07-25-2014, 05:14 AM   #3
Papajack: Your July 4 fillup is marked as a partial fill. When there's a partial fill, no immediate calculation is done for that fill, or the next. This data is still used in your overall lifetime vehicle average though. If this is an error, edit the fillup again, and uncheck partial fillup, and you will receive calculations for the past 2 tanks.
Old 07-25-2014, 05:21 AM   #4
Arrow
Your previous entry only has an odometer reading. The database is probably treating this as a partial fill. I don't think the programmers have maintenence entries implemented in the database yet. This is something that is scheduled for future release. I would edit your last fillup, and in the notes section put the date and mileage of the oil change, and delete the oil change entry. Then it should calculate as normal.
Old 07-25-2014, 10:03 AM   #5
RobertV's Avatar
Actually, mark23487, take a look at your Log Book-
http://www.fuelly.com/car/ford/range...487/291706/log
Your last fill up on the 25th shows an odometer of: 66,895. This is 60000 more than you had on the 24th!
I'm guessing this was a typo. Simply edit and correct.
Old 07-25-2014, 06:22 PM   #6
Thanks!
for the reply
