mpg incorrect - Fuelly Forums
Old 07-15-2014, 09:21 AM   #1
mpg incorrect
2nd fillup and MPG incorrect. Entered 133.1 miles and 8.69 gallons and when I ''save'' it shows 13. miles and 1.5 MPG it will not allow the proper mileage to be entered.
cquester5 is offline   Reply With Quote
Old 07-15-2014, 11:10 AM   #2
RobertV's Avatar
You're currently tracking via Odometer.
Looking at your Log Book confirms this:
http://www.fuelly.com/car/toyota/tac...er5/300677/log
If you need to change the tracking method of your entire fuel-up history, it's best to create a new vehicle with your preferred tracking method and use import/export to add your previous fuel-ups.
Old 07-15-2014, 05:08 PM   #3
Country: Ireland
Entered in 166 but only 56 shows up in odometer reading and cant edit this whatsoever
Then says 10mpg which is wrong
whizzcom is offline   Reply With Quote
Old 07-15-2014, 08:08 PM   #4
RobertV's Avatar
Which vehicle? Which entry? Can you provide a screenshot?
Old 07-15-2014, 08:50 PM   #5
mine is reading 80 litres as 21 gallons when it should be 17.6 gallons,is it on usa gallons and how do i change it?
mickseaT5 is offline   Reply With Quote
Old 07-16-2014, 01:31 AM   #6
The tech was right I was using the ''odometer'' reading to track fuel and when I tried to enter 133.1 miles it appeared as 13 miles. I would have thought the odometer would have been the correct way to track, but, apparently miles is the correct setting. I changed it and all appears correct now.
