Voltstats doesn't let me record fuel costs, gasoline or electric.
You seem to be supporting the Prius Plug-In, another plug in hybrid vehicle, albeit PiP drivers struggle to achieve 200+ mpg.
As far as a comparison with other vehicles, gallons of gasoline consumed is still a valid comparison.
Why not remove the limit, or require a checkbox to confirm the data entry when the 200+ limit is exceeded?
I have considered adding kWh fuel ups, using the EPA's 33.7 kWh = 1 gallon of gasoline. You could make that entry easier by supporting kWh as a unit like liters.
