km dont work - Fuelly Forums
Old 08-23-2014, 09:38 AM   #1
km dont work
Not able to enter correct data in kilometre . ex enter 526.6 km and then it show something like 41...no sense at all ,even when trying to edit it dont work
civicjdm is offline   Reply With Quote
Old 08-24-2014, 10:51 AM   #2
km don't work.
You have 6 Vehicles on the Fuelly Website. Your original post failed to mention which vehicler you are referring to, that is giving the problem on posting the Kms on.
Could your Flash/Java Be slow in calculating, and then does not show up fast enough for a screen refresh.
Try Logging out, Clearing Cache in Browser, Then Resetting PC,and Re-logging back in. (just as a guess at this point).
PS> let the team know which vehicle you are trying to update.
Looked at 1st two Vehicles. 1st seemed ok, but you are missing $ per litre on severall fuel ups. Throsw of your latest L/100 km rate.
On the second vehicle, your Kms entered are NOT TRIP kms. Fuelly takes YOUR ODOMETER (ACTUAL) and compares it to the PREVIOUS (LOWER ODOMETER VALUE) to calculate the number of Kms driven.
According to the review of 'All Fillups Diplay' you are inputting the number of Kms since the last fillup. 526 to 527 km gives 1 km driven. 40 litres filled up translate to 4000 L/100 km driven.
Re-Edit the table for the entries (based on date), and use ACTUAL ODOMETER, not the trip odometer from the last fillup.
I Hope this helps.
CobourgVeeDubYah is offline   Reply With Quote
Old 08-24-2014, 11:35 AM   #3
here is what it SHOULD look like. See Picture Attached.
Old 08-25-2014, 09:01 AM   #4
I Hope this helps.
Thanks a lot you where Wright , i change odometer reading to trip and everyting is allright now!
Old 08-26-2014, 05:34 AM   #5
RobertV's Avatar
civicjdm,
Glad you got it figured out!
CobourgVeeDubYah,
Thanks for helping a fellow Fuelly Driver!!
