Incorrect MPG calc and mileage - Fuelly Forums
Old 07-01-2014, 11:12 AM   #1
Hi all
First post
I have had a problem since the update with mileages not showing correctly and therefore MPG being calculated wrong, I've checked what I've entered and I'm correct but the system has worked it out wrong.
On my log book it's entries 32, 31 and 22.
Help!
Cheers
Adam
addyboy is offline   Reply With Quote
Old 07-01-2014, 12:26 PM   #2
Site Team
What do you believe is wrong about the entries? Below are your totals on Old and New Fuelly. The fuelups you pointed out appear to be the same on both.
Old / New
ID:	1605 Click image for larger version
freddie is offline   Reply With Quote
Old 07-01-2014, 02:28 PM   #3
In that case old is wrong as well. I didn't do 1154 miles between fill-ups and I've checked the mileages I've entered and the difference between them is not 1154 miles.
I'm confused :-S
Old 07-03-2014, 10:26 AM   #4
RobertV's Avatar
Hi Adam,
So looking at your Fuel log: http://www.fuelly.com/car/renault/la...boy/232828/log
I've discovered a few questionable entries that may need some review on your side.
Apr 11 2014
61,548 Odometer
Apr 19 2014
65,731 Odometer
Apr 5 2014
64,577 Odometer
As you can see April 5th's Odometer reading falls between that entered on April 11th and April 19th. Either the dates or the odometer were swapped. Please correct and that should resolve your discrepancies.
As for fuel-up #22 (Feb 14th) I'm not sure what the problem with that one is. Can you explain the issue?
