Well, starting with a partial is not really recommended as you should really start with a known quantity.... a full tank. No matter what algorithms are used, the entire premise of starting to track mileage with a partial tank is flawed. This is what I would do. At your next fuel stop, fill your tank. When inputting the data, enter the date to be the same date as fill #1. Then edit Fill #1, and change the date to the current date. This will swap the fills, and the system will begin calculations with a "full" tank. Things will still be a little off as there isn't enough data in your fuel log to fully absorb a partial tank at this point, but at least your calculations will start from a known point.
