Working As Designed: How to change default car for fill-up in GasTracker+ - Fuelly Forums
Old 06-09-2014, 07:01 AM   #1
I just downloaded the GasTracker+ app under iOS, how do I change the default car being filled up?
When I click the round, orange button on the main screen of the app to add a fill up it defaults to my GTI. I want it to default to my STi.
How do I change this?
I tried changing the order of the cars in the app, but that didn't work and there doesn't appear to be a setting anywhere to change the default car.
thanks!
2015 STi & 2013 GTI
idburns is offline   Reply With Quote
Old 06-09-2014, 12:37 PM   #2
Site Team
You need to set the default as your primary vehicle here:
https://www.fuelly.com/add/profile.gas
The current version of GasTracker+ has about 48 hours before you will have to download the upgraded version. On the new version it's designed to remember the state it was last in. So if you typically fill up your default car but you also have your wife's car linked to your account. When you open the app it will revert back to the vehicle that was last accessed. Assuming that was your car, it will go directly there for adding a fuel-up. You will still be able to access your wife's car from the menu on the left when needed.
andyrobo is offline   Reply With Quote
Old 06-09-2014, 02:09 PM   #3
I went into my profile and set my primary to the STi (it wasn't set at all) and now the STi appears first both at fuelly.com and in the app but clicking the orange button in the app still brings up the GTI as the default.
I force-quit the app, restarted it and it is still showing the GTI.
Ahh, was fiddling while I was replying. Logging out of my account in the app, and then logging back in fixed it.
Thanks!
2015 STi & 2013 GTI
Old 06-12-2014, 08:27 AM   #4
Thanks!
This should work the same way in the latest GasTracker update just released yesterday.
Fuelly iOS Developer & Team Window Washer
joshlehman is offline   Reply With Quote
