Filter by Imperial vs. U.S. Gallons? - Fuelly Forums
Old 05-01-2013, 06:55 AM   #1
I was interested in checking out the average mpg of a VW Golf. I was surprised to see it so much higher than the U.S. EPA estimate. Then I realized that much of the data is coming from non-U.S. sources and that it may be reported as Imperial Gallons. Are the U.S. Gallons and Imperial Gallons mixed together when reporting? Or is there a filter to show the results in one vs. the other. If they are mixed, then I don't know how I could use the information I am getting.
Thanks!
bvz2000 is offline   Reply With Quote
Old 05-01-2013, 07:57 AM   #2
Top left hand corner you can switch between US or UK gallons (or others) You will see all figures adjust accoedingly
Old 05-01-2013, 08:01 AM   #3
Oh and if the MPG'S are higher than expected, its due to a number of reasons. In Europe, I would guess that 75% of Golfs are diesel, 85% are manual transmission too. Combine that with higher emission regulations and more refined fuel, and its no wonder the fuel consumption is lower.
I think the Bluemotion Golf in Europe gets over 90 MPG.
Old 05-02-2013, 03:37 AM   #4
Aha. Thanks for pointing out the units up there. Never saw it.
Still, it would be nice to be able to filter by region. I tried to set the golf to be just gas engines using the filter, but there are several different gas engine choices, none of which I understand. If I were to be able to filter by fuel type AND region then I would be able to limit my results to those engine choices I know I can buy wherever I live. And as you mention, choice of transmission is also a relevant data point.
As an aside, right now when I try to filter the results down to 2012 Golf's and I set the engine type to Gas, I still get two TDI's listed (maybe the owners have just misclassified their cars).
Anyway, thanks for the help.
Old 05-02-2013, 08:33 PM   #5
I did suggest a filter on 'all petrol' vs. 'all diesel' to avoid the wierd engine configuration stuff, but Fuelly like to keep their site as simple as possible so it was rejected.
