Enter in Partial Fill-Ups - Fuelly Forums
Old 08-20-2008, 12:59 AM   #1
Complete Fill-Up every time? Fuelly is caculating my MPG wrong due to my partial fill-up.
I put some gas into my car last night, only about 2 gallons, but Fuelly went ahead and assumed that I went my 355 miles on 2 gallons. So my question is am I allowed to enter partial fill ups? Maybe we need a check box allowing such? Or did I hit a bug?
Date: 8/19/08
Miles driven since last fill up: 355.0
Gallons bought: 2.040
Price per gal: $4.09
Estimated MPG: 174.0
Yeah...I wish I got 174 MPG
ozreiuosn is offline   Reply With Quote
Old 08-20-2008, 01:02 AM   #2
pb
We're adding a partial fill-up option today. We're planning to have it added to the site before the end of the day.
Old 08-20-2008, 05:55 AM   #3
Thank you! Ill just delete that entry and redo it when you add the feature.
Old 08-20-2008, 07:44 AM   #4
pb
Partial fuel-ups are available now.
Old 08-21-2008, 06:29 AM   #5
I don't understand why a partial fill up can't calculate the MPG if you're putting in an odometer reading every time.
If I put 2 gallons in for a partial fill up and I went 70 miles I got 35mpg.
Old 08-21-2008, 06:53 AM   #6
ozreiusn, I explain the way fuel ups work in calculating mileage on another thread.
If you don't fill up a tank all the way, it simply doesn't work even if you are using odometer. The problem is you can drive 300 miles and only get 2 gallons. Your next fuel up might be 10 gallons after only 40 miles (to make up for the low fuel), but the non-fillup and followup throw your average completely off.
Here is a spreadsheet with test data, assuming I have a 20 gallon tank and my car always gets 20 mpg (and the odometer started at zero with the first fill-up).
You can see from the data that the non-fillup throws the MPG way off into the 150mpg range, and the subsequent 2.67mpg fill up doesn't bring the average back to 20mpg
mathowie is offline   Reply With Quote
