Default Car? - Fuelly Forums
Old 03-06-2011, 04:40 AM   #1
Default Car?
I have three cars listed on Fuelly, and sometimes I enter several fuel-ups for the same car at once. Each time I go back to do another entry, I have to re-select that car because another one is listed in the box, and it's not first alphabetically. Is there a way to avoid selecting the same car over and over?
jerryc41 is offline   Reply With Quote
Old 03-06-2011, 06:51 AM   #2
pb
There are a couple different ways you could do it.
1.) You can set a primary vehicle in your profile. Go here and set a Primary Vehicle (it's the 3rd option from the top). That vehicle will come up when you go to fuel-up.
2.) Go to the profile of the vehicle you want to fuel-up. Click the red "Add a fuel-up" button at the top of the page. You'll go to the fuel-up page with that vehicle selected. Bookmark that page in your browser and that vehicle will come up every time you use that bookmark.
3.) Use fuel-up importing. If you have more than three fuel-ups or so it might be worth jotting them down in a text file and using the import feature instead of entering them manually.
Old 04-04-2011, 03:32 PM   #3
TnS
How about adding a add fuel-up button on the page after you enter the fuel up data that way we can just keep adding more fuel up for the same vehicle without having to click on the vehicle profile. 1 click vs. 2 clicks.
TnS is offline   Reply With Quote
