Bug - multiple fillups on the same day - Fuelly Forums
Old 02-14-2009, 01:09 PM   #1
I seem to be running into a bug when I report multiple fill-ups on the same day. What happens is that the program is treating the latest fill-up on a given date as the *first* fill-up on that date, for calculation purposes. For instance, if I fill up with Exxon in the morning and Sunoco in the evening, Fuelly thinks that the Sunoco fill-up came first. The only way around this that I have found so far is to report same-day fill-ups on different dates, which is not as elegant as I'd like.
NBtarheel33 is offline   Reply With Quote
Old 02-14-2009, 11:05 PM   #2
pb
Thanks for letting us know. Sounds like we should add times for fuel-up dates so there's no ambiguity.
Old 02-15-2009, 06:42 PM   #3
Yep, that would be the ideal solution. In fact, I found that a way around this issue was to add times to my Excel spreadsheet before importing data, and then a 3pm fillup gets recorded before a 6pm fillup, for instance.
Old 02-17-2009, 09:49 AM   #4
Ran into the same issue when I imported my data. As mentioned, the work around was to fudge the dates, which was OK, but is obviously not intuitive.
fitzski is offline   Reply With Quote
