Adding Vehicle. - Fuelly Forums
Old 01-20-2012, 10:34 AM   #1
Adding Vehicle.
Everything but Make is grayed out.
Trying to add a vehicle to the Garage, but when I go to start only option I can change is what make I want to add. Everything else stays grayed out and unclickable. Any suggestions?
CrimsinRain is offline   Reply With Quote
Old 01-20-2012, 11:00 AM   #2
pb
Sounds like you have JavaScript disabled. Check your browser settings to make sure JavaScript is enabled. If you're not sure how to do that, let me know which browser you're using and I can give you a hand.
If you have another browser available to try, you might give it a shot there. For example, if you're using Firefox you might try adding a vehicle in Internet Explorer and see if that works. If you're using Chrome on a Mac you might try it in Safari instead.
Old 01-20-2012, 06:29 PM   #3
You were correct, sir. Thank you for your support!
