Adding fuel info from months past - Fuelly Forums
Old 03-16-2015, 11:01 AM   #1
I keep an exact paper log of my mileage as my fuel gauge doesn't work. I went back to Aug 2014 and put in all my information. THEN I found my sheet prior to that start date. Can I put those older fill ups in now?? Will it mess anything up? (I have a specific reason for wanting to track from June 2014). Thanks
tiffany186 is offline   Reply With Quote
Old 03-16-2015, 11:19 AM   #2
BDC
You can enter them now, just make sure you put the proper date in when you add the fillup. Fuelly will sort them by date.
BDC is offline   Reply With Quote
Old 03-16-2015, 11:23 AM   #3
Great! Thanks, BDC!
Old 03-16-2015, 12:18 PM   #4
Hopefully once you've added all your fuel ups, your average should even out a bit. At the moment, its reading less than double digits so its way off!
Old 03-16-2015, 01:00 PM   #5
Unfortunately, it is accurate. It's a motorhome. Most all of them get about 8 mpg. Also, part of the gas usage is the generator when it is sitting still...so that's averaged in there, too. And I do very little highway driving...mostly back roads. I live in it full time. Thanks, tho'!
Old 03-16-2015, 01:57 PM   #6
Wow OK!
Old 03-16-2015, 09:06 PM   #7
Arrow
Yes, as mentioned by BDC, as long as you enter the proper dates (and times if you have multiple fillups in the same day) everything will be automatically put in the correct place.
