Adding fill ups - Fuelly Forums
Old 03-28-2012, 06:15 PM   #1
Adding fill ups
I filled up this morning, so when will I need to add this morning fill up data, will it be now or when I next fill up?
Jonseyt23 is offline   Reply With Quote
Old 03-28-2012, 06:22 PM   #2
Add your recent fillup data now. You need to mark how much mileage was done on your tank or how much mileage your car has on its odometer. I prefer to mark how much mileage of every tank.
You also need to mark how much you paid per unit of fuel.
2013 Mazda 3 GS-SKY 6MT (Current)
2015 Mazda 3 Sport GX 6MT (Lease return)
2013 Mazda 3 Sport SKY-SKY 6AT (Ex's daily driver - totalled)
2007 Toyota Matrix Base 5MT (Sold)
MatrixDom is offline   Reply With Quote
Old 03-28-2012, 06:31 PM   #3
Hi matrix, I added the data from the last fuelling just now, which was 122miles driven @ 143.7p per litre and 15.12 litres. I fully filled up before work this morning do I add this now as I cant put how many miles I have driven on this tank also cannot input odometer reading as its broke, well the lcd has anyway.
Regards
Old 03-29-2012, 12:19 AM   #4
pb
Jonesyt23, you might take a look at the 2nd video on this page. That might help explain a bit more how Fuelly works.
Whenever you fuel-up, note the details and add it to Fuelly at that time. One trip to the pump = one entry at Fuelly. If you don't have a tripometer or odometer reading, then you'll have to wait until the next time around when you do.
Old 04-06-2012, 01:18 PM   #5
Country: Malaysia
Hello there...
I'm new here. I'm having problem to key in my data because i'm confuse which data should i key in at Kilometers since last fuel ups. Because, now my car showing 14129KM, with 22.633l and RM1.90 (Malaysia). After i key in everything, the system said :
We found the following problem with your submission, please correct:
Looks like the number of kilometers you entered is unrealistic for a single tank. If you really went 14129 kilometers for this tank, click Fuel-up! below to bypass this check.
What does it means?
Larrie85 is offline   Reply With Quote
Old 04-06-2012, 03:54 PM   #6
pb
It sounds like you need to switch from tripometer tracking to odometer tracking. Take a look at this FAQ: What's the difference between tracking with Trip Miles vs. Odometer?
