To cool. Couple of questions. Sorry to rapid fire them at ya:
How heavy is the shell and total weight of HPV?
I can't remember exactly, but I think the shell was something like 20-30 pounds, and the frame right around there too. Mind you, the shell was made WAY too strong.
What's the size (teeth) of the big change ring? Is it set up with a single speed hub? If so what the gear ratio?
Again, I can't remember - either a 44 - or 53 I think.
I guess you have 300m to speed before the trap. Do you know what kind of wattage is required to reach that speed?
Not at all :/ Sorry
Does it heat up pretty quickly inside when your working hard?
When fully sealed - yes. We solved that problem this year with NACA ducts.
And last for now. Has anyone tried the superman postion instead of the recumbent for the HPV? I would thing that you might be able to develope more power that way or does it require a bigger shell?
Yes.
1. It's very difficult to get it right so that you can maintain stability
2. You can get more power down - usually sacrificing rider comfort
3. A team did that two years ago, and crashed everywhere :/
Sorry for the 20 questions but this really is cool.
No worries
I wish I could answer more of them :P
Question 21: does the aeroshell make it noisy inside? Something tells me that might be an issue, transmitting/amplifying vibration & road jolts...
Less wind noise - but yes, you the fairing does make some sound when you hit bumps. It's not
that big of a deal though. This year we have a better mounting scheme that should help in that department
