Creative Night With the Coroplast - Fuelly Forums
Go Back   Fuelly Forums > Alternative Fuels > People Powered
Old 10-19-2006, 10:51 PM   #1
I was having a good time with a good teacher of mine, Dr. Karkov, when we thought up this idea...
A few zipties on the steering bars got it mounted up, so we decided to take it for a quick spin. I quickly found out that only mounting it to the handle bars would allow it yaw forward eventually being sucked underneath the front wheel causing a quick crash (Mental Note: save testing for the morning. I then added zipties lower on the brake levers to prevent this from happening again. I took it for another drive and it is noticeable faster, even though the majority of me is still exposed to the air. It also gets slightly wider then my legs right behind them, so i'll have to deal wtih that too.
Old 10-19-2006, 11:20 PM   #2
While not the ideal solution , Ime sure it does do something
Old 10-19-2006, 11:23 PM   #3
That's what i was thinking, later i'm planning on adding a tail section just behind my legs, I'm still afraid off all the drafts goin in on the top, the bottoms close enough to the ground to be less important i believe. I'm also thinking of a Diamond shaped thing instead of a coat, I've got soo much coroplast to play with now!
Old 10-19-2006, 11:58 PM   #4
Corplast sheet is good stuff.
I made a 2 meter wingspan RC glider from it a couple of years back and it flew ,, badly , but it did fly.
Biggest problems is joining it , most glues dont work so many people use large staples and such like.
To get tight bends in line with the stripes you can cut one side with a blade.
If you cut about every 2cm you can form some very nice bends.
Old 10-20-2006, 09:21 PM   #5
DRW
Here's a little inspiration for ya
http://www.windcheetah.co.uk/gallery.htm
Dave W.
can't add/change photo to forum badge ByronBrewer Fuelly Web Support and Community News 8 09-28-2011 05:58 AM
Log and Facebook MPG issue gherkin Fuelly Web Support and Community News 2 08-06-2011 03:12 AM
Joint Membership with GasBuddy? Badams Fuelly Web Support and Community News 2 07-02-2011 12:14 AM
Crashing-Not good for mileage! diamondlarry General Fuel Topics 17 01-03-2006 05:58 AM
obd0->obd1 distributor wiring harness Matt Timion General Maintenance and Repair 2 11-09-2005 08:57 PM
