ultra quick bike conversion - Fuelly Forums
Old 08-12-2007, 08:02 PM   #1
skewbe's Avatar
I don't know if it will go fast/far enough to matter, maybe going through the gears would help, but here is a quick and dirty conversion idea that may or may not work if you have a bike laying around and a spare $50 for a trolling battery:
Standard Disclaimer
Old 08-12-2007, 08:11 PM   #2
GeekGuyAndy's Avatar
Are you going to be trying that?
GeekGuyAndy is offline   Reply With Quote
Old 08-12-2007, 08:18 PM   #3
skewbe's Avatar
I wish. Seriously, the wife would kill me if a bike showed up. I just wanted to put it out there.
Standard Disclaimer
Old 08-12-2007, 08:23 PM   #4
"Oh what's that dear? There's a bike on the front step? Who put that there?" Think she'd fall for it? Being a moped driver I always wondered why I hadn't seen any electric mopeds around. I bet that would be an easier/smaller conversion
Old 08-12-2007, 09:13 PM   #5
GasSavers_Ryland's Avatar
main problem that I see is that the starter motor is designed to run for up to 10 seconds at a time, when I've worked on bikes, and ran the starter for more then 10 seconds I noticed that it got really hot, about 30 seconds and it gets hot enough to burn your self on, the bearings and brushes are also designed for short bursts, and not continued running, a starter might see up to an hour of total use befor being rebuilt if you add up every 2 second burst that it's used.
it's also geared low enough that if you are lucky, in 5th gear you might get up to 15mph
Old 08-13-2007, 10:22 AM   #6
I actually have a Tomos Bullet Moped with a bad engine in it. I plan on converting it to Electric in the coming months. I have several options, just not sure how much money I want to drop into it. The cheapest involves using a modified car starter.
sandalscout is offline   Reply With Quote
Old 08-12-2007, 09:54 PM   #7
skewbe's Avatar
Ok, safe to say that this goes in the "you'd have to be bored" category
Standard Disclaimer
Old 08-13-2007, 04:58 AM   #8
Maybe something the size of a car starter would work. If you put a one-way freewheeling clutch on it, then you could run the starter for a few seconds, and then coast, and then run it, and then coast.... The starter could go down where the motorcycle crank is/was.
Old 08-13-2007, 11:59 AM   #9
How about just taking out the engine, put in a 12v DC motor and belt that to a wheel?
Old 08-23-2007, 08:18 AM   #10
That's the plan in the most basic form, but I've got to source a controller, batteries, charger, etc... I plan on mounting the motor roughly where the engine was, and running it off of the original chain drive. I've not sat down and TRUELY figured it out, so I'm not sure what voltage/amperage ratings I need, etc....
Windows Mobile 6 IE failure brentil Fuelly Web Support and Community News 2 08-29-2008 01:34 AM
Ca-40g Snax Experiments, Modifications and DIY 21 06-07-2007 08:00 AM
SuperMID - suggestions for Improvement? landspeed General Fuel Topics 2 03-07-2007 07:05 PM
'98 Metro 1L 5 speed MrEvolution Introduce Yourself - New member Welcome 2 01-03-2007 10:31 AM
Simplistic Layout Matt Timion Fuelly Web Support and Community News 7 05-19-2006 03:11 PM
