ultra quick bike conversion - Page 2 - Fuelly Forums
Old 08-23-2007, 05:12 PM   #11
I have sort of wondered if you could avoid the controller, and just have an on/off. In a high enough gear, the starting shock would not be too much...
Old 08-23-2007, 07:52 PM   #12
But the current draw would be big.
One of the good things about a controller aside from the smooth, smooth goodness, is it protects the motor, wiring & battery from excessively big amps.
Of course if you instrumented the thing with an ammeter and did a little bit of testing to learn what gear/speed/grade combos work without heating up the components too much, AND you keep an eye on the meter, a simple switch would be OK.
Old 08-24-2007, 05:14 AM   #13
Ah, yeah, I tend to forget that electric motors will happily, peacefully destroy themselves if you ask too much of them.
Old 08-24-2007, 05:21 AM   #14
Then again, you could also just put a properly sized fuse or circuit breaker in there with the switch. That'd protect the motor without a controller. (Should be a fuse in there anyway so if the controller fails, you still have motor/circuit protection).
Windows Mobile 6 IE failure brentil Fuelly Web Support and Community News 2 08-29-2008 02:34 AM
Ca-40g Snax Experiments, Modifications and DIY 21 06-07-2007 09:00 AM
SuperMID - suggestions for Improvement? landspeed General Fuel Topics 2 03-07-2007 08:05 PM
'98 Metro 1L 5 speed MrEvolution Introduce Yourself - New member Welcome 2 01-03-2007 11:31 AM
Simplistic Layout Matt Timion Fuelly Web Support and Community News 7 05-19-2006 04:11 PM
