Question about EV motors. - Page 2 - Fuelly Forums
Old 08-03-2006, 01:33 PM   #11
The Toecutter's Avatar
One more thing, is it in any way possible to have some kind of regen system, so I could set the wheel down and have it spin the motor in reverse to recharge the batteries.
Yes, but not with a series wound DC motor.
You'll need either an AC setup(inverters are expensive) or a seperately excited DC motor(affordable home-brew control systems are complicated).
Most EV enthusiasts don't even bother. Regen only extends range by 10-15% anyway.
Old 08-03-2006, 04:01 PM   #12
omgwtfbyobbq's Avatar
In an all electric maybe, but I was thinking about using it for deceleration when using the diesel too. So I could grab all that energy that would've gone to the brakes and recharge the batteries with it. Do you have any idea what the efficiency of a seperately excited DC motor is?
Old 08-03-2006, 06:36 PM   #13
You could also stick an alternator or generator on the tail shaft of a normal series wound DC. I've seen that done once or twice.
Old 08-03-2006, 08:55 PM   #14
Hmmm... I wonder if the output is clean enough to charge a NiCD battery? In any event it's something to tinker with. Thanks!
Old 08-04-2006, 02:39 AM   #15
reconfigure an alternator for high voltage output to recharge at 36-48 volts and figure on recharging lead bats right after use - nicads not so often but they have a greater charge/discharge energy loss.
Hyundai Active Eco System DurhamRich General Fuel Topics 4 05-25-2012 01:46 PM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 06:37 AM
Fuelly for Maintenance? brandonrossl Fuelly Web Support and Community News 11 01-05-2009 04:09 AM
Leaning fuel mixture and effect on engine temp Flatland2D General Fuel Topics 18 12-16-2005 10:11 PM
