I got an EV! - Page 2 - Fuelly Forums
Old 11-17-2007, 07:01 AM   #11
lovemysan's Avatar
Yes, it will spin the inside tire taking a left turn. Its quite an amusing thing to ride. It has lights, signals, brake lights, and horn. The horn barely works under full throttle. The controller distributes power to all the accessories.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 11-17-2007, 07:20 AM   #12
skewbe's Avatar
Originally Posted by lovemysan View Post
...The horn barely works under full throttle...
LOL!
Standard Disclaimer
Old 11-17-2007, 09:06 AM   #13
Tuggin at the surly bonds
Silveredwings's Avatar
I tested it out today. It really will go 8-10mph. Its got a range of about 5 minutes at full throttle. I'm going to balance the pack tomorrow.
Maybe you need a solar bimini.
Old 11-17-2007, 07:07 PM   #14
lovemysan's Avatar
The battery pack is pretty sad. It will go about 300 yards nice and then start puttering out. I also think my pack wiring is hurting it. I used crimp connectors and 16g wire.
Evbike conversion
I went to the local bike shop today to see if he had any ideas about a drive system. He wasn't any help at all. He said I was wasting my time. I'm trying to do this on a severely restricted budget. Free! I nabbed another bike from the trash today. So far in the last three months I've been unable to find a decent rear wheel.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-17-2007, 08:55 PM   #15
ajohnmeyer's Avatar
Send a message via AIM to ajohnmeyer
I think my favorite idea for how to mount a motor is to do it off of a tandem crankset. That way you can get the advantage of using all of your gears with the motor, on the downside is that when the motor is running the pedals are turning. It's not exactly the cheap way to go, but it seems like the most effective way to use a motors (relatively) small torque band.
To clarify, a motor doesn't have a small torque band, but a bicycle has an ENORMOUS range of gearing. A motor tied to the wheel at a fixed ratio will either not have much starting torque or will run out of torque at the top end of your bikes speed range.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." -The Drive By Truckers
Team OPEC Busters!
ajohnmeyer is offline   Reply With Quote
ebay ScanGauge 1 MetroMPG Hypermiling 1 06-26-2007 08:16 PM
Cooling fan mpg DRAG....?? ZugyNA General Fuel Topics 4 06-12-2007 01:29 PM
Engine compartment airflow roadyj General Fuel Topics 4 06-02-2007 09:05 AM
Jet Beetle diamondlarry General Fuel Topics 0 03-02-2006 03:49 PM
Leaning fuel mixture and effect on engine temp Flatland2D General Fuel Topics 18 12-16-2005 10:11 PM
