electric vehicle (bike/motorcycle) on the cheap? - Page 2 - Fuelly Forums
Old 06-29-2007, 05:35 PM   #11
skewbe's Avatar
Originally Posted by JanGeo View Post
I have a 1hp electric motor all set to drive my front crank with a one way sprocket - just need to make the motor bracket and get the darn left crank off to mount the gear and fix the front wheel spokes. Then I get all 21 gears available on my mtb with a brushless motor drive and LiIon battery pack made from laptop cells to run it all of which I have already plus full suspension.
more specs please, what voltage and amp hour, how many cells, how you controlling it, how far and fast do you predict?
Standard Disclaimer
Old 06-29-2007, 05:52 PM   #12
The motor is a PowerPack motor kit with controller programmable for several voltages - actually it just works over a wide voltage range. No regen of course but a bike doesn't really need it. It is rated for 35-40 amps and 42 volts I think. It has a plantary gear reduction on the motor. The LiIon cells I have are 2ah 5amps output max and I have about 70 of them so a 10x7 pack will give me 35 amps and 42 volts max but I will probably run them at a lower voltage and more amps. What is nice is the battery should weigh about 10 lbs - not bad for a 36 volt nominal 14ah pack about 1/3 that of lead.
Old 06-29-2007, 06:10 PM   #13
skewbe's Avatar
cool, just curious, in staying with the "cheap" theme of this thread, how much for 70 laptop batteries? And how do you charge them?
Standard Disclaimer
Old 07-11-2007, 03:01 AM   #14
the only problem of electric motorcycle is the battery, i have bought one china scooter but now the battery is dead i dont know where to buy it china battery with higher amperes.
jackmty999 is offline   Reply With Quote
Old 07-11-2007, 09:17 AM   #15
Lightweigh cost money - with 50+ quantity pricing on the Lithium cells 2ah each go for about $3.80 each, I forget what the shipping was.
Old 07-11-2007, 03:38 PM   #16
GasSavers_Ryland's Avatar
one electric vehicle web site I saw pointed out "an electric vehicle is only as good as it's battery" this is why my electric bike is still waiting for a better battery.
Old 07-12-2007, 10:56 AM   #17
Good news is that it should be good for about 1000 cycles and they don't run down by themselves much so you don't have to keep pumping power into them to keep them up. Bad news is that they age even if you do not use them so . . . buy them at the last minute!
Text message directions missing scshelton Fuelly Web Support and Community News 1 06-03-2010 03:02 PM
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 07:41 AM
Crude oil price hits $73.85 Mighty Mira General Discussion (Off-Topic) 4 06-30-2006 09:01 PM
