No worries. I found it pretty heavy going (I'm an electronics dunce) but over the course of about a month I've progressed to the point where I'm able to make working versions with their own PCB's. If I can pick it up,
anyone can
A DMM is good for showing you the OCV of the batteries, and if you can juggle it, the voltage under load, but a hydrometer will give you a better indication of the actual condition of a flooded battery.
A brief note about electric motors (I apologise in advance if you already know this), their torque curve is very different to an ICE. As motor rpm approaches peak, torque approaches 0. So, the faster they rev, the less torque they have, though obviously there's a sweet spot between rpm and torque. While we're talking torque, current is roughly proportional to torque, and voltage is roughly proportional to rpm. So more amps = more torque and more volts = more rpm. The tradeoff is that too much current = excess heat and too many volts (above the rating in a brushed motor) = accelerated brush wear and arcing on the commutator. In extreme cases overspeed will cause the rotor to come apart which is why you must never run a series wound motor at it's rated voltage with no load. Again, there's always a sweet spot.
I generally treat the ratings as a rough guide
If you go too far over them, some forced air cooling via a fan to cool the windings is a good idea. Electric motors are rated at their continuous power output anyway, peak output is normally at least twice the continuous. I guess what I'm trying to say is find out how much current your controller is rated to deliver, use some Ohms Law[1] to figure out how many Watts you're delivering to the motor. Voltage sag under load will effect things significantly, but it give you a starting point to play around with anyway.
You might want to consider an ammeter and shunt (I got mine from
http://www.evparts.com but maybe you can get one from another forklift or something). You could use a friend holding a DMM plus the ammeter readings to get an idea of voltage sag under load, and also how much current your batteries can actually deliver to the controller.
Gerrys evconvert.com site is what brought project forkenswift to my attention. I've been hooked ever since
I'd love to do a car, but not gonna happen in the foreseeable future (getting a modified car registered here is nothing that bulk $$ can't fix
BTW, I just watched your video (forgot to yesterday). I loved it! There's nothing so sweet as the sound (or lack of it) of an EV cruising down the street. I especially loved the EV1 rip off at the end, classic
Cheers,
Ash
[1] i = v/r where i = current in amps, v = volts and r = resistance (watts)
http://en.wikipedia.org/wiki/Ohm's_law
You can shuffle things around like in any equation and I prefer to think of it this way: Watts = Volts * Amps. So if your "ESS" is 36V and it's delivering 100A to the motor; Watts = 36 * 100 = 3600W (incorrectly assuming no voltage sag under load).
