Good news on that reversible motor. Are you thinking of keeping it in one gear?
Originally Posted by Silveredwings
...anyway, I'm ready to test the pump and do the leak checks (so many fuel connections). I'm sure everything will work the first time.
I should say that's a gating item. I need to get all that squared away before I set the car down (off the stands, it has about 3" of ground clearance, so it's hard to fix stuff underneath). Once back on terra firma, I need to rotate the engine to verify nothing's stuck, and prime the oil pump (rolling the car in gear is the most practical way I can think of doing this). Atleast it has fresh 20w50 oil w/ stabilizers in it. Then I need to see if the starter still works. It's kind of like "if I had some ham, I could have ham and eggs...if I had eggs."
..of course, I should test the ignition for sparks too before I waste time cranking the beast.
Oh, I can almost smell it now.
