Electric conversion: Project ForkenSwiift - Page 21 - Fuelly Forums
Old 11-06-2006, 01:01 PM   #201
The motor shaft is about
Old 11-06-2006, 01:03 PM   #202
Originally Posted by The Toecutter
You should seriously consider aeromods to this thing to increase top speed and extend range.
Don't forget this is only going to be a neighbourhood type vehicle. Average speed will probably be 30 km/h.
Old 11-06-2006, 01:05 PM   #203
Also... that motor adapter plate looks thick enough to withstand a 700 hp big-block Chevy!!!
Which is exactly my plan when I get bored with the electric thing! Just saving on future machining costs...
Old 11-06-2006, 01:25 PM   #204
Lateral thinking. Gotta love it.
It'll cause lateral driving too.
Old 11-06-2006, 04:48 PM   #205
Tuggin at the surly bonds
Silveredwings's Avatar
Originally Posted by MetroMPG
The forklift controller has an "acceleration ramp" built in, and I believe it's also adjustable via a pot. On the plus side (?) We're running relatively low voltage from a small pack, so we're not going to be putting out prodigous amps (relative to the Tesla roadster, for example).
I don't follow that volts-to-amps relationship.
I thought the soft coupler was pretty clever too, until I talked to a commercial EV builder last week. He suggested we were going to wear out/chew up that urethane spacer in short order, and actually said a fixed connection between the motor & input shaft would have been fine.
If there's any play at all, I would expect it to get bigger, especially if you're planning on supporting regen brakes (alternating torque in either direction - I didn't say it that time ).
I anticipate great things from this project.
Old 11-06-2006, 05:50 PM   #206
This evening: axles out, exhaust removed, shift linkage disconnected.
At what point did it become apparent that I'm completely winging this?
No regen - just "go!" So the wear is in one direction.
I anticipate breaking things! All in good fun though.
Old 11-06-2006, 07:12 PM   #207
kickflipjr's Avatar
So how much more before you get that thing on the road?
2008 EPA adjusted:
Old 11-06-2006, 07:47 PM   #208
I don't want to predi
Old 11-07-2006, 05:51 AM   #209
Theoretically, inside 2 or 3 weeks we could have the electric drivetrain in, so we could hook jumper cables between a couple of batteries and the motor, and off we go! Does that count?
I think that does count. It's the current thing to do.
I don't think jumper cables have enough surface area in contact with the battery cables to handle the current you'd need (even in a test). The clips will probably heat up, and may even burn them at the contact points (you might be shocked to find the battery terminals burned as well), but I may be wrong. Don't let this impede your progress, just keep an eye on it. I read about many EV builders who regularly check and tighten their battery terminal connections because of the effects the high current has on them. One of the advantages of going with higher voltage is lower current:
Volts * Amps = Watts (Watts law)
But you may not be able to change the top voltage your motor/controller can take, so don't get too wired about it.
The other potential problem is the voltage drop across the jumper clips in proportion to the current:
Ohms * Amps = Volts (Ohms law)
So you want to minimize the ohms (unit of resistance) wherever you can: thick cable, heavy duty terminal connections, high surface area connections to your controller, fuse(s), motor, kill switch (eventually), etc. Try to have as little 'etc.' as possible.
Old 11-07-2006, 08:34 AM   #210
As a matter of fact, we a
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 06:41 AM
Converting numeric to current tire sizes. omgwtfbyobbq General Maintenance and Repair 5 06-01-2007 04:51 AM
Prius. First Impressions zpiloto General Fuel Topics 17 09-03-2006 10:49 PM
