Electric conversion: Project ForkenSwiift - Page 80 - Fuelly Forums
Old 10-11-2007, 02:12 PM   #791
skewbe's Avatar
Very cool, can't wait for some real world stats (0-30 times, top speed, range, etc).
So where is the garage entry already?
P.S. what is downshifting like without a clutch (spinning the motor up on the synchros?) or do you not do much shifting or hows that work?
Standard Disclaimer
Old 10-11-2007, 06:35 PM   #792
Right... garage entry! I should get on that.
What formula will I use for MPG equivalent though? There are 33,557 watt hours in a gallon of gas, and the FS pack theoretically (when new) holds 48v*220AH (I think) = 10,560 watt hours (less than 1/3 of a gallon of gas, equivalent energy!)
Problem is, I don't have a killawatt meter, so I don't know exactly how much I'm putting back into the pack when I recharge. Suggestions? I can estimate SOC from pack voltage... but that's kind of like estimating MPG based on where you gas gauge was before topping up.
Old 10-11-2007, 06:41 PM   #793
Whoops missed this:
Old 10-11-2007, 07:43 PM   #794
skewbe's Avatar
I gotcha on the shifting.
re monitoring efficiency: I had this whole DIY Kill-a-Watt thing typed out, then went to ebay and searched for "Kill A Watt" and the dang things are $22 shipped, LOL. 15 amps max, don't know what a car charger needs.
Standard Disclaimer
Old 10-11-2007, 07:48 PM   #795
Hrm. One of the chargers is 20A, the other is 5A. So if I feel like waiting 24h to recharge the car using the 5A unit, I could measure it.
EDIT: wait a minute... it charges at 20A DC. 110v AC amperage will be less.
I should get a killawatt anyway...
Old 10-11-2007, 07:53 PM   #796
Get it, sucka!
Old 10-11-2007, 07:57 PM   #797
Otay, Panky!
Old 10-11-2007, 08:08 PM   #798
trebuchet03's Avatar
If you don't have a killawatt or other way to measure current draw.... Turn off/unplug everything in your house except for your charger and check out the power meter -- measure how much power it's using....
Hrmm... that only works if you know how long the charger is running....
Do those cheap multimeters do AC current for any appreciable current?
As for gas equivalent....see if you can figure out how wrightspeed calculated the equivalent mpg - his EV gets 170mpg eq.
http://www.wrightspeed.com/
Doing a google search yields all sorts of results.... Some are based on energy content, others are on emissions equivalent...
From the wiki entry on battery EV's -- but that section is tagged as not having a source
BEV operating costs can be directly compared to the equivalent operating costs of a gasoline-powered vehicle. A gallon of gasoline contains about 36.4 kWh of energy. To calculate the cost of the electrical equivalent of a gallon of gasoline, multiply the utility cost per kWh by 36.4. To calculate the equivalent mileage of a BEV, divide 36.4 kWh/gal by the energy efficiency in kWh/mile, to get the equivalent miles per gallon. For example, if a BEV owner's electricity rate is $0.10 per kWh, and the BEV gets 0.20 kWh/mile, then the owner is paying the equivalent of $3.64 per gallon of gasoline, and getting the equivalent of 182 miles per gallon.
Yet again, another post that looks like I'm playing darts... I'm all over the place
11/12
Old 10-12-2007, 02:15 PM   #799
Congrats! ...really glad to hear that it worked out.
Old 10-12-2007, 04:05 PM   #800
Thanks, Rick!
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 06:41 AM
Converting numeric to current tire sizes. omgwtfbyobbq General Maintenance and Repair 5 06-01-2007 04:51 AM
Prius. First Impressions zpiloto General Fuel Topics 17 09-03-2006 10:49 PM
