Originally Posted by MetroMPG
I believe (but am not certain) that two 36v strings in parallel will halve the amps that each string sees, so yes, it might reduce Peukert's and extend range. (In series, I think each battery sees full amps.) On the other hand, at 36v, you need more amps to do the same work.
In a loud announcer voice "You are correct sir!" ding ding ding.
Personally I would lean towards 48v bank at this point, like you noted it's less batteries overall and less load per battery for the same "speed" and more potential top end power
but not for as long as 2 strings of 36.
