 MetroMPG Adapter 07-21-2006, 01:32 PM
 MetroMPG It's 12-26-2006, 07:32 PM
 MetroMPG AS 12-28-2006, 08:26 AM
 SVOboy Yessir. 04-05-2007, 03:17 PM
 MetroMPG Rear... 09-08-2007, 10:01 AM
 MetroMPG Nah 10-12-2007, 04:17 PM
 JanGeo motor 02-05-2006, 07:04 PM
 JanGeo eCycle 02-06-2006, 04:19 AM
 JanGeo 4 door 02-24-2006, 03:53 AM
 JanGeo welding 03-06-2006, 04:50 PM
 JanGeo yup 03-11-2006, 06:44 PM
 JanGeo 16,000 03-15-2006, 06:26 PM
 JanGeo lift 03-16-2006, 02:30 AM
 JanGeo Yeah 03-21-2006, 06:20 PM
 JanGeo motors 03-22-2006, 02:36 AM
 JanGeo hybrid 03-22-2006, 07:30 PM
 JanGeo locos 03-23-2006, 04:37 PM
 JanGeo rust 04-04-2006, 03:42 PM
 JanGeo parts 04-05-2006, 07:35 PM
 JanGeo red 04-06-2006, 04:34 PM
 JanGeo outside 04-08-2006, 03:54 AM
 JanGeo low 04-09-2006, 04:22 AM
 XFi Midget 04-09-2006, 02:57 PM
 JanGeo test 04-12-2006, 07:49 PM
 JanGeo Curtis 05-10-2006, 06:42 PM
 JanGeo curtis 05-11-2006, 03:44 AM
 JanGeo drains 05-12-2006, 07:01 AM
 JanGeo Floor 05-12-2006, 06:44 PM
01-07-2007, 06:54 PM
Tuggin at the surly bonds
Originally Posted by brelandt
I think my Sidekick would be a good canidate for a EV project as well.
I think I saw an older Sidekick/Tracker conversion for sale a while ago. I wonder if it's still around.
01-08-2007, 12:49 AM
If range at speeds over 30 mph isn't a serious concern, go for it.
01-08-2007, 05:06 AM
Watched the DVD, "who killed the electric car" tonight.
Me too. (Again.)
We actually started out watching for one of these as a host. Toecutter's right - only really suitable as a "town car" due to aerodynamics.
would it be wise/economical/ludicrous to use Romex
I'd never heard of Romex before you asked. I looked it up and it appears to be plastic sheathed cable. But is it structural cable or electrical? (good conductor?) Flexibility isn't necessarily a problem - you just have to plan more carefully. Some people use bent copper bus bars for battery interconnects.
01-08-2007, 04:11 AM
Moderator
I'm just curious - for wiring up an EV, would it be wise/economical/ludicrous to use Romex for the wiring? I know lack of flexibility would be a downside, but would there be any others?
01-08-2007, 04:55 AM
Can you get romex in 2/0 or 3/0 AWG? If not, it will heat up and maybe catch on fire. If you have to bunde it, how will you connect it to batteries and things?
01-08-2007, 07:59 AM
01-08-2007, 09:29 AM
Moderator
Originally Posted by MetroMPG
Nice! Is the 20 km/h in 1st gear? What do you estimate it will be with 48V?
I'm not sure what sizes Romex comes in, but I was wondering if it was good enough for a house (120V), will it be good enough for this (48V)? How many amps is the Forkenswift going to see? What's the max amp rating on typical romex? (general questions for anyone  )
01-08-2007, 10:16 AM
A quick check of ohms law (and AWG sizes) tells me if you put only 15 HP into the motor on a startup (15HP x 746W/HP), you'll be cranking over 11kW through the wires. At 36 V, that'll require over 310 Amps. 12 guage wire in your house walls is great for a 15A circuit, but it has over 27 times the resistance of say 3/0 guage wire. That added resistance multiplies by the amperage and results in a voltage drop (and heat loss).
For example, 20' of 3/0 ga. copper is about 0.00124 ohms. At 310A, that drops about 0.38 V, or about 119W dissipated in the wire. With 12 ga. copper wire, the same length is 0.034 ohms and at 310A, that's 10.5V dropped and over 3kW dissipated (though this becomes a self limiting system about this point: the more resistance, the lower the current and HP output).
Resistance also goes up with temperature and that all your connections will add resistance losses as well so you want to minimize resistance wherever you can. Also, copper wire does work-temper as you bend it (not as bad as Al) and so goes up in resistance at those bends. It's small but cummulative. Solid wire is worse in this respect than stranded wire.
This is one reason why the more engineered EV designs go for higher voltage systems in order to keep peak current lower: fewer resistance losses in motors, wires and connections, lower weight conductors, etc. This is also why many people say that an EV's performance is more limited by the controller's capacity than the motor - as in what's the peak current capability of the controller?
YMMV.
01-08-2007, 10:44 AM
Hmm - learned something new today. Thanks for the lesson.
01-08-2007, 10:58 AM
The forklift controller limit is in the neighbourhood of 400A, but it also has a bypass, which will feed full battery current to the motor under certain (logic) conditions.
That must be analogous to a tourque-converter lockup clutch.  It does make a lot of sense. At those high amperages, the semiconductors are just ohmic switches dissipating a lot of loss because of their even slight resistances. If the duty cycle of the PWM gets close enough to 100%, it might as well use a relay (metal) instead of silicon.
EDIT: that should mean that the system should be more efficient at the equivalent of WOT.
BTW, silicon resistance goes down with temperature. That's why there have to be preset thermal or current limits or they will fuse together (read self-destruct). When you do overload a power transistor, you will be able to see glowing silicon a split second after it pops the lid off the device's case and a split second before it clouds the view with smoke. Don't ask me how I know this.
