12-30-2006, 10:30 AM
If you want to do that kind of range on a budget, you're going to need a small, efficient car to keep battery cost per mile of range down. The batteries will be your largest budget component.
You're definately going to need a lightweight car, with lots of efficiency modifications. A heavy, unaerodynamic pickup truck will drive the battery costs for 60 miles range over your budget.
Try to throw out a few specific vehicles, and I might be able to recommend some setups to you. You will definately be doing a lot of scrounging for used surplus starter-generators and you will need to learn how to build your own contactor controller. It's pretty simple to make a battery charger with a bridge rectifier circuit as well.
One of your N600s looks like a great choice of donor, but you might have to remove the back seats to get enough battery room. And its aerodynamics aren't very good; you'll need aeromods. Even at a modest 30 mph, they will make a pretty noticable difference in range. LRR tires can extend range greatly as well.
