brainstorming an electric vehicle - Fuelly Forums
Old 12-29-2006, 10:42 AM   #1
Matt Timion's Avatar
I know, I just bought a new car...
but I want to build an electric car. if anything as a commuter for my wife or for running to the grocery store.
requirements:
cheap conversion (maybe $2000-ish?)
easy conversion (duh!)
at least 60 mile range on a charge
the first thing I think of us a small pickup truck. The bed can hold the batteries and I won't need to do much fab work to get them to fit. If it's mainly a commuter, aerodynamic issues won't come into play (neither wife or I get on the freeway to go to work). There is also the possibility of adding a small solar array to the bed to help charging in the future.
But I think it would also be fun to convert something like an older honda, or maybe an older VW Bug.
Anyway... would love to hear any suggestions.
Old 12-29-2006, 10:45 AM   #2
zpiloto's Avatar
How about a n600 or mybe a VW rabbit circa 1980's
Old 12-29-2006, 11:27 AM   #3
Moderator
GasSavers_DaX's Avatar
Please don't cut up any of your 600's...
Old 12-29-2006, 12:22 PM   #4
I hate to be a downer, but 60 miles is going to be a serious challenge in a budget conversion. You'll need a lot of batteries. I know Toecutter's got the weight/range/cost formulas at his fingertips. He may chime in.
Don't forget to factor in a 25-50% range reduction in winter temperatures. Is there no way of charging half way, at work?
Old 12-29-2006, 01:54 PM   #5
If my wife drives it, it can easily be recharged at work. If I go for the truck conversion, I can do the solar panels eventually.
In all reality, my wife works 3 miles away. I'd like to overshoot actual numbers though, because a vehicle with a 10 mile range isn't too impressive.
I DID see a guy on that austinev site that converted an old late-70s honda civic with a 60 mile range.
Old 12-29-2006, 02:38 PM   #6
But adding range that you don't really "need" just sets up a vicious circle of decreasing efficiency (from added weight, assuming lead acid) and escalating costs to manage that decreased efficiency: more range = more battery weight --> more cabling --> bigger host vehicle --> larger motor --> more powerful controller --> stronger charger --> more batt maintenance (assuming floodies) ...
Since an EV will only ever be a second car for most people with current battery tech, just aim for what you need.
Old 12-29-2006, 02:40 PM   #7
omgwtfbyobbq's Avatar
What are your top speed requirements, how many stops on the route, are there large hills, what's the weather like? Given your budget, I'm going to suggest going with a smaller pack with a custom genset... That way you can make sure the pack is always between 30-80% charge in order to extend it's life, get a significant amount of power from the grid, while not having to worry about running out of charge.
Old 12-29-2006, 02:50 PM   #8
Team GasMisers5!
landspeed's Avatar
Buy a small diesel generator, and use that to power your electric motor, or charging system etc. Then you can have a 10 mile range on batteries, and have a backup plan if you run out of power
Edit : seeing the post above, looks like I took to long to post
Hypomiler
Old 12-29-2006, 05:53 PM   #9
Can I have the old first gen rex?
Old 12-29-2006, 09:17 PM   #10
That's the wife's car... not mine... besides, I'm going to be painting it soon
Text message directions missing scshelton Fuelly Web Support and Community News 1 06-03-2010 02:02 PM
How do I start? Enter my first fuel up? thirtythreedragons Fuelly Web Support and Community News 2 10-07-2009 06:18 AM
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 06:41 AM
