a/c and electric cars - Fuelly Forums
Old 06-25-2009, 10:01 AM   #1
can air conditioners be installed in vehicles that have been converted to 100%electric? if so, can i assume that running one draws a large amount of amps?
LarryJ is offline   Reply With Quote
Old 06-25-2009, 10:13 AM   #2
Well,you can always install a 12 volt rooftop air conditioner - that's the easiest solution, however you'll take a huge hit in your arerodynamics unless you're installing it on an RV, bus, or van. If you've converted a Geo Metro to electric its not that practical. Otherwise it can be done, but I imagine that the motor you install to run the compressor will probably take a lot of power to run.
Old 06-25-2009, 12:25 PM   #3
The Prius uses an electrical compressor. Don't know about its power requirements.
A company that does Ranger conversions, EVlion I believe, leave the factory a/c in place, and run it off the drive motor.
Old 06-25-2009, 07:14 PM   #4
Compared to the power needed to move the car the electric motor driven A/C compressor is not using a lot of power. Remember you have high voltage in an electric car. eCycle sells their motor as a compressor drive for trucks that usually run off 24 volts but it can run on 12 volts at up to 400 amps depending upon the compressor load.
Old 06-25-2009, 08:09 PM   #5
After looking around, this company seems to have a decent selection of units. Their 12 volt unit uses 30 amps @ 12 volts. Very doable...
http://www.sunpowertech.com/residential.htm
Old 07-27-2009, 01:47 PM   #6
rgathright's Avatar
Nice find!
rgathright is offline   Reply With Quote
Old 08-26-2009, 09:37 AM   #7
cat0020's Avatar
But at $2699.00 you could buy a decent used car with A/C.
Old 08-26-2009, 10:43 AM   #8
... or tile the roof with peltier elements.
Should I attempt a SS header-exhaust on my VX jadziasman General Maintenance and Repair 8 07-06-2011 07:21 PM
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 07:41 AM
Air Dam and Bellypan Material GasSavers_rayjay Aerodynamics 22 06-13-2008 11:38 PM
