"Related" threads
<p>well, the conversion would be the same, except that there would be no place to put the batteries. you could put some up front, but not enough to get good range. my bus would HAVE to have a 200 some mile range, so that we could visit family. hell, the roof's flat, maybe we could even set up some sort of solar panel, too. that would come later and be complicated, though, to get it to charge something wired at 100 some volts. I have still yet to get pictures. I figure at max, i can fit about 30 optima yellow tops. ten batteries wired in series in each group, and all three groups wired in parallel. it would be expensive, but it would barely fit and should give me the range i need. i wonder what tax writeoffs i could get. 120-132 volts should be more than enough to move all those batteries. the bus is perfect because it's light but has a tremendous hauling capacity rating. too bad it's as aerodynamic as a loaf of bread.<br /><br /> </p>
